EX-B150M-V5 D3
Discussion in 'BIOS/UEFI' started by technical, Oct 7, 2015.
    ASUS EX-B150M-V5 D3
    BIOS EX-B150M-V5-D3-ASUS-0406 16MB
    [​IMG]
    • CPU
      Intel® Socket 1151 for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors
      Supports Intel® 14 nm CPU
      Supports Intel® Turbo Boost Technology 2.0
    • Chipset
      Intel® B150
    • Memory
      2 x DIMM, Max. 32GB, DDR3 1866(O.C.)/1600/1333 MHz Non-ECC, Un-buffered Memory
      Supports Intel® Extreme Memory Profile (XMP)
      * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
      * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V.
    • Graphic
      Integrated Graphics Processor- Intel® HD Graphics support
      - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz
      Maximum shared memory of 512 MB
    • Expansion Slots
      1 x PCIe 3.0/2.0 x16 (x16 mode, gray)
      2 x PCIe 3.0/2.0 x1
    • Storage
      Intel® B150 chipset :
      4 x SATA 6Gb/s port(s), gray,
    • LAN
      Realtek® 8111GR, 1 x Gigabit LAN Controller(s)
      ASUS LAN Guard
    • Audio
      Realtek® ALC887 8-Channel High Definition Audio CODEC featuring Crystal Sound 2*1
      - Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
    • USB Ports
      6 x USB 3.0/2.0 port(s) (4 at back panel, , 2 at mid-board)
      6 x USB 2.0/1.1 port(s) (4 at back panel, blue, 2 at mid-board), 2 port(s) supports USB Over-Voltage Protection
    • Special Features
      ASUS 5X Protection II :
      - ASUS LANGuard - 2.5X higher surge tolerance
      - ASUS Overvoltage Protection - World-class circuit-protecting power design
      - ASUS DIGI+ VRM - 7 Phase digital power design
      - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits
      - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability
      Non-stop Durability :
      - Anti-moisture coating - Outstanding protection against moisture and corrosion
      - USBGuard- 120% higher voltage tolerance
      - Anti-theft memory - Locked-down memory for everyday security
      Non-stop Gaming :
      - LED-lit Audio Shielding: Ensures precision analog/digital separation and greatly reduced multi-lateral interference, with a gorgeous illuminated trace path
      - Dedicated audio PCB layers: Separate layers for left and right channels to guard the quality of the sensitive audio signals
      - Audio amplifier: Provides the highest-quality sound for headphone and speakers
      - Premium Japanese-made audio capacitors: Provide warm, natural and immersive sound with exceptional clarity and fidelity
      - Unique de-pop circuit: Reduces start-up popping noise to audio outputs
      - Top notch audio sensation delivers according to the audio configuration Separate layer for left and right track, ensuring both sound deliver equal quality
      Non-stop Challenger :
      - ASUS iCafe Labs Certified - Top games and 100+ peripherals tested
      ASUS Exclusive Features :
      - AI Suite 3
      - Ai Charger
      - PC Cleaner
      ASUS Quiet Thermal Solution :
      - ASUS Fan Xpert
      ASUS EZ DIY :
      - ASUS EZ Flash 3
      - ASUS MyLogo 2
      - ASUS UEFI BIOS EZ Mode
      ASUS Q-Design :
      - ASUS Q-Slot
      - ASUS Q-DIMM
    • Operating System Support
      Windows® 10 , 64bit
      Windows® 8.1 , 64bit
      Windows® 7 , 32bit/64bit *2
    • Back I/O Ports
      1 x PS/2 keyboard/mouse combo port(s)
      1 x DVI-D
      1 x LAN (RJ45) port(s)
      4 x USB 3.0 (blue) Type-A
      4 x USB 2.0
      3 x Audio jack(s)
    • Internal I/O Ports
      1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
      1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s)
      1 x TPM header
      1 x COM port(s) connector(s)
      4 x SATA 6Gb/s connector(s)
      1 x CPU Fan connector(s) (1 x 4 -pin)
      1 x Chassis Fan connector(s) (1 x 4 -pin)
      1 x 24-pin EATX Power connector(s)
      1 x 8-pin ATX 12V Power connector(s)
      1 x Front panel audio connector(s) (AAFP)
      1 x System panel(s)
      1 x Clear CMOS jumper(s)
    • Accessories
      User's manual
      I/O Shield
      2 x SATA 6Gb/s cable(s)
      1 x Supporting DVD
    • BIOS
      128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.7, ACPI 5.0, Multi-language BIOS,
      ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions, and ASUS DRAM SPD (Serial Presence Detect) memory information
    • Manageability
      WfM 2.0, DMI 2.7, WOL by PME, PXE
    • Support Disc
      Drivers
      ASUS Utilities
      EZ Update
    • Form Factor
      mATX Form Factor
      8.9 inch x 7.6 inch ( 22.6 cm x 19.3 cm )
    • Note
      *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output.
      *2: Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7.
    Similar Threads - B150M Forum Date
    Schematics PC GA-B150M-D3H DDR3 Schematics Aug 16, 2019
    Schematics PC GA-B150M-EVO Schematics Aug 16, 2019
    BIOS PC CF-G10-MX V20 B150M-K BIOS/UEFI Jul 2, 2019
    Schematics PC ASUS B150M-ET M2 Schematics Jul 1, 2019
    BIOS PC GA-B150M-DS3H BIOS/UEFI Jun 21, 2019
  3. technical
    Asus EX-B150M-V5D3
    Boardview TSICT
