ASUSPRO P2540UV
Discussion in 'BIOS/UEFI' started by technical, May 21, 2017.
    ASUSPRO P2540UV BIOS
    • Processor
      Intel® Core™ i7 7500U Processor,
      Intel® Core™ i5 7200U Processor,
      Intel® Core™ i3 7100U Processor,
    • Operating System
      Windows 10 Home - ASUS recommends Windows 10 Pro.
      Windows 10 Pro - ASUS recommends Windows 10 Pro.
      DOS
    • Chipset
      Integrated Intel® CPU
    • Memory
      DDR4 2400MHz SDRAM, 2 x SO-DIMM socket for expansion, up to 16 GB SDRAM
    • Display
      15.6" (16:9) LED backlit HD (1366x768) 60Hz Anti-Glare Panel with 45% NTSC
      15.6" (16:9) LED backlit FHD (1920x1080) 60Hz Anti-Glare Panel with 45% NTSC
    • Graphic
      NVIDIA GeForce 920MX
    • Storage
      Hard Drives:
      500GB 5400RPM SATA HDD
      500GB 7200RPM SATA HDD
      1TB 5400RPM SATA HDD
      Solid State Drives:
      256GB SATA3 SSD
      Solid State Drives:
      512GB SATA3 SSD
    • Optical Drive
      Super-Multi DVD (Optional)
    • Keyboard
      Chicklet keyboard with isolated Num key
    • Card Reader
      Multi-format card reader (SD/SDHC/SDXC)
    • WebCam
      VGA/HD Web Camera (Optional)
    • Networking
      Integrated 802.11a/b/g/n/ac(2x2)
      10/100/1000 Base T
      Bluetooth
      Built-in Bluetooth V4.1
    • Interface
      1 x Microphone-in/Headphone-out jack
      1 x VGA port/Mini D-sub 15-pin for external monitor
      3 x USB 3.0 port(s)
      1 x USB 2.0 port(s)
      1 x RJ45 LAN Jack for LAN insert
      1 x HDMI
    • Battery
      6 Cells 72 Whrs Battery
    • Power Adapter
      Plug Type :ø4.5 (mm)
      Output :
      19 V DC, 4.7 A, 65 W
      Input :
      100 -240 V AC, 50/60 Hz universal
      3/ 2 pin compact power supply system
    • Dimensions
      380 x 256 x 23.3 ~26.3 mm (WxDxH)
    • Weight
      2.17 kg with Battery
    • Security
      Kensington lock
      BIOS Booting User Password Protection
      HDD User Password Protection and Security
      TPM (Trusted Platform Module) (Optional)
      Finger Print Reader
    • Certificates
      UL, CE Marking Compliance, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, GOST-R, CB, EPEAT, EU Flower, Energy star, IDA, CECP, WEEE, Erp 2013, RoHS, JATE
    • Manufacturer Warranty
      2-year limited International hardware warranty. *different by country
      2 year battery pack warranty on 4cells
      2 year battery pack warranty on 6cells
    Similar Threads - ASUSPRO P2540UV Forum Date
    BIOS PC ASUSPRO D840MA BIOS D840MB BIOS/UEFI Aug 15, 2019
    BIOS PC ASUSPRO BM1845 BIOS/UEFI Aug 15, 2019
    BIOS PC ASUSPRO D540MA BIOS D540MC D540SA BIOS/UEFI Aug 15, 2019
    BIOS PC ASUSPRO D425MC BIOS BIOS/UEFI Aug 15, 2019
    BIOS PC ASUSPRO D641SC BIOS BIOS/UEFI Aug 15, 2019
Tags:
