ASUS FX753VD
Discussion in 'BIOS/UEFI' started by technical, May 21, 2017.
    ASUS FX753VD BIOS
    • Processor
      Intel® Core™ i7 7700HQ Processor,
      Intel® Core™ i5 7300U Processor,
    • Operating System
      Windows 10 Home
      Windows 10 Pro - ASUS recommends Windows 10 Pro.
    • Chipset
      Intel® HM175 Express Chipset
    • Memory
      2 x SO-DIMM socket , up to 32 GB SDRAM
    • Display
      17.3" (16:9) LED backlit FHD (1920x1080) 60Hz Anti-Glare Panel with 45% NTSC with 178˚ wide-viewing angle display
      17.3" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display
    • Graphic
      NVIDIA , with 2GB/4GB GDDR5 VRAM
    • Storage
      Hard Drives:
      1TB 5400RPM SATA HDD
      1TB 7200RPM SATA HDD
      2TB 5400RPM SATA HDD
      Solid State Drives:
      128GB/256GB/512GB SATA3 M.2 SSD
      Solid State Drives:
      128GB/256GB/512GB PCIE Gen3X4 SSD
    • Optical Drive
      Super-Multi DVD
    • Keyboard
      Illuminated Chiclet Keyboard
    • Card Reader
      Multi-format card reader
    • WebCam
      HD Web Camera
    • Networking
      Wi-Fi
      Integrated 802.11b/g/n
      Integrated 802.11 AC
    • Interface
      3 x USB 3.0 port(s)
      1 x USB 2.0 port(s)
      1 x USB-C Gen 1 (up to 5 Gbps)
      1 x RJ45 LAN Jack for LAN insert
      1 x HDMI
    • Battery
      4 Cells
      mAh 48 Whrs Battery
    • Power Adapter
      Plug Type :ø5.5 (mm)
      19 V DC, 6.32 A, 120 W
    • Dimensions
      418 x 255 x 30 ~ cm (WxDxH)
    • Weight
      2.8 kg with Battery
    Similar Threads - ASUS FX753VD Forum Date
    Schematics PC XIN SCHEMATIC HOẶC BOARDVIEW ASUS H110M-D Schematics Nov 24, 2021
    ASUS FX504GE BIOS FILE (312,317,318) BIOS/UEFI Sep 25, 2021
    BIOS PC bin ASUS B450 plus tuf gaming Ver.1201 BIOS/UEFI Apr 24, 2021
    ASUS X550VX.asc BoardViewer Schematics Apr 28, 2020
    ASUS X411UA Schematic Schematics Apr 22, 2020
Tags:
